Show us your DIY tools, workshop equipment.
    Was sick of tripping over my mig and having to carry the bottle around. Cheap bunnings trolley and some scrap metal I had laying around.
    GAS 260Z RB26DET
    GAS 1600 3SGE BEAMS
      Had an old dishwasher lying around. Wanted a sand blaster.
      So far cot is nill. But I need to buy gloves and screen and light. Already have a portable sandblasting kit I'll be using inside.
      RNJ Fabrication
      Design-Machining-Welding
      RNJfabrication@yahoo.com
      04 0737 0736
        Nice effort guys
        _/ /___________\ \_
        /_________|_________\
        |OOO ___________ OOO|
        \______|====|______/
        [_]-------------------[_]
          Started with this
          Cut and made holes
          Ended up with a end sand blasting unit.
          Also
          Small tool for the lathe.
          That's all for now
          RNJ Fabrication
          04 0737 0736
            I have a few ill take some picks just hand tools.
              OK, I'm intrigued. What is it ?
                looks like he is machining brake discs or something to that effect
                Originally posted by Marv
                  Bingo.
                  Allows you to turn both sides parallel. You skim one side with the tool then change tools to skim the other side.
                  In the past I have just turned the disk around and then used the dial gauge to get it parallel. Time consuming but effective. It's little jigga saves me heaps of time.
                  RNJ Fabrication
                  04 0737 0736
                    Made this tiny vice.
                      Ahh, vey good.
                        Originally posted by kneelo View Post
                        my ghetto line boring rig... cost me $100 for some bright shaft and bearings vs $400 a machine shop wanted to put it on the horizontal boring machine or $2k a mobile line borer wanted.
                        [ATTACH=CONFIG]57223[/ATTACH]
                        [ATTACH=CONFIG]57224[/ATTACH]
                        Good work man! That's pretty good! What were you line boring? We use sub zero at work and they do great work but priced accordingly!
                          Its a top mount attachment to fit a rock breaker to an excavator.
                            Bingo.
                            Shit I've machine heaps of rotors and prob can do it with my eyes closed but I have no clue how that little jig works!
                              It appears you machine one side then undo the lock swing the jig around and machine the other side of the rotor.
                                Bingo.
                                A mate has a nice little tool with both a left and right cutter and a dial to set the distance between them - it does both sides at once.
