Replacement drill chucks?
    So my new'ish Hitachi cordless drill's chuck is well fucked.
    I never really liked how it worked, so would prefer not to replace it with the same one.
    The chuck on it is a "Jacobs 4000 Series" 1.5mm-13mm.
    I haven't had anything to do with chucks before other than using them.
    Can I use a chuck from another brand?
    Any recommendations?
    Thanks chaps.
    Anything that's the same Jacobs taper size (probably a #1 Jacobs taper - # 2 if it's particularly heavy duty.) will work - if you can get it off ok.
