Angle grinder proliferation
    Originally posted by garvice View Post
    Have dedicated grinders, still need to move guard, more so when cutting then grinding. Use to run no guard but put the guard back on as it's the quickest way to hang them, don't even need to wait for disc to stop. My Hitachi I can spin the guard with the grinder running (I know, shouldn't do that, going to pay for it one day).
    I've got a Bosch 5" that has a rotatable guard with a spring loaded lock thingo. I'll get a picture of it, works well and takes no time or effort to move.
      I picked up two of these at Bunnings for $50 each on clearance. Good buy if you can find some locally.
      cool, need to use mine a bit today and see if it is usable for anything but grinding, think i've got enough grinders for now.
        Thanks guys, I ended up going Metabos for a 4" that has a tooless guard. Seemed to be the only one that came with a slide switch and was tooless in a 4"size. Lots in 5" but not in 4".
        Customer Cars
        GAS FAB XM Coupe - PerformanceForums
        GAS FAB Mk1 Escort - PerformanceForums
        GAS FAB - 1985 Porsche 911 3.2ltr Carrera Cabriolet - PerformanceForums
        GAS FAB Cars
        GAS 260Z RB26DET
        GAS 1600 3SGE BEAMS
          just gave it a blast, seems a bit gutsier than the bosch.
          Bosch 5" weighs 1.8kg, ozito 5" weighs 2.45kg. I wondered if it was approaching 9" size so dragged out my ancient AEG, it isn't anywhere near as big and the AEG 9" weighs 6.3kg.
            I use a Metabo 4" at work, they are a great grinder, won't bog down. I prefer a 4" most of the time as it can get into tight spots easier. Also I use the worn down 5" consumables on it as well.
              What do the $300-$400 grinders offer over and above the (say) $100 grinders?
                Not sure about the $3-400 ones. My 4" Metabos were about $180. So still twice as expensive as the ~$100 specials I was getting (Metabo also do a $100 4" special).
                Main reason I bought the metal was the tooless guard change and the slide switch. Just couldn't get that combo elsewhere in the 4". Only had them for probably 6 months so don't know if they'll longer.
                It's also meant to have a safety clutch so cutting discs don't grab (haven't had that kick in yet). It's body is more the size of my 5"grinders so bigger/more powerful internals.
                Some of the bigger sizes have things like dampened handles (I don't use handles on 4").
                Customer Cars
                GAS FAB Cars
                GAS 260Z RB26DET
                GAS 1600 3SGE BEAMS
                  I bought one of the $300 Makitas purely for its variable speed, to make better use of strip-it disks. Going slow lets them cut Vs. going fast and melting them. Exxy grinder has more power than the cheaper Makitas too, but that's no real advantage IMHO.
                  Originally posted by Marlin
                    The grinders in that price range will generally be more powerful between 1400w to 1700W, metabo make the 1700W version. They will also have features such as variable speed, soft start, restart protection so the thing won't take off when you have accidently left the switch on and then plugged it in, a brake to stop the disc spinning within a few seconds, auto balancer so it won't fuck you hand if you are doing a lot of grinding, also generally makes the grinder smoother.
                    Probably a bit overkill for home use, but if you are on the grinder regularly it would pay itself off in no time.
                      Dont they have different size centres?
                        Yeah they do, 5" is 22mm bore and 4" is 16mm.
                        If you carefully centre it and do up the nut tight with the spanner it will stay put. Just make sure it is on centre otherwise it will vibrate like crazy.
                        The proper way to do it would be to machine up a bush or turn down a washer to suit.
                          Circular saw reducer bush could fit, I think the speed rating for 4.5 and 5 inch wheels is the same, but lower than 4 inch wheels. That said the spigot size on a 9 inch grinder is the same as a 4.5/5 IIRC.
                            Yeah never run a bigger wheel than the grinder is designed for. Over in America they run there grinders without guards, that's just stupid IMO.
                            Yeah 9" is the same bore size as 4.5"/5"
                            In industry there is a lot of wastage, they just get binned with plenty of life left in them,
                            I'll pretty much run them down till there is no abrasive left on them.
                              Speaking of Angle Grinders. I have a 20+ year old Arlec grinder I bought from KMart for like $25.00, Still going stong, and still my go-to 100MM grinder when having really nice Bosch and AEG Grinder in the same size.
