Restoring a "cast" finish after welding/linishing
    Another vote for sandblasting, have done it on old vintage bike engine and gearbox castings that had been repaired and needed to look "original" .
      Just came across this video:
      https://youtu.be/4oXrMe8heKE?t=236
      It looks like you can get a really nice look with the right type of engraver.
        Looks like a vibration engraver. Can pick them up for $25 or so. Might have to try it
          Wrinkle black?
          PS sandblasting - but make sure you protect faces & threads etc
            Picked up a cheap vibration engraver tonight and gave it a go.
            Has certainly reduced the shiny finish a bit, but its still quite a lot cleaner/fresher than the surrounding casting. I read somewhere about bluntening the tip slightly and going over again, so ill try that.
              Unless you either clean the rest or artificially age the weld area, you're always going to get some contrast in the colour. Freshly machined/welded metal is always going to look cleaner than metal that has been in an engine bay for 30 years.
                Sandblasting will sort it.
                Use something course.
                  For thread closure, after several attempts at sand blasting with out getting a satisfying result i ended up going the old fashioned route:
