Garrett GTX3576R V-Band Inlet - Odd size for piping???
    I have a Garrett GTX3576R turbo with V-Band Inlet. this is the V-Band flange for the turbo.
    it has a 55mm ID, 67mm OD however I'm unable to find any 55mm stainless pipe to use with it.. The exhaust manifold is 2", same with the up pipe... but yeah bit stumped on the best way to go about making it work with the up pipe..
    /csh Racing
    Sounds like it might be similar to the flange typically used with indycar, which is designed for 2 1/4" tube, not pipe.
      SCH10 2" pipe has an internal diameter a bees dick under 55mm
