Sump repair on vehicle - silver solder?
    The sump on my race car has a small pin hole in one of the welds which weeps a small amount of oil, this was recently repaired but it's still got a very small leak. Pulling the sump off in the car is a massive pain in the ass and I really don't want to pull the engine out so was wondering if silver solder is a viable way of fixing the hole? Ideally I would just TIG it but the weld is between the sump wings and the pain rail and you'd never get the torch in there.
    TK built the motor and he suggested just using some epoxy but I've never had much luck with it, thoughts?
    https://sydneytools.com.au/product/s...SABEgI0RfD_BwE
      Would hold easily if you can get to it, nice and clean with no oil. You wont be able to do an over head repair if you know whati mean
        Yep have used the epoxy stuff to repair pinhole leaks in a fuel tank (while it was still leaking out), it outlasted the rest of the car. Soldering basically impossible with oil contamination all over where you'd be attempting to fill I reckon.
          Righto, I'll give it a bash.
            Heat the area, brush with wire brush to clean the flakey shit off, flux then solder. Add a degreaser step 1 if its real oily.
              Step 1 : drain oil
                and leave the oil cap off. there's an explosion/fire risk from hot oil vapour. can you just oxy or tig it up?
                Originally posted by Skompa
                  Kneadit should do the trick if you clean area up as much as you can before using it.Different types available from Bunnings at cheaper price
                    There is a low cost Devcon option you can get now. I've never used it before but Devcon always had a good reputation.
                    https://www.ebay.com.au/itm/Devcon-P...frcectupt=true
                    I've previously used JB Weld to do a repair that never should have worked.
                    Prep work is the key, make sure the area is not contaminated with oil.
                      i have had WAY more success with JB weld than knead it and this was a fuel tank repair
                      knead it was fucked and just wouldnt stick, didnt seal and just fell of
                      jb weld was solid as all fuck, i made it too high and and had to grind it back it was like steel.
                      www.holditflat.com
                        Here's the 3 i did a test-run with
ID:	7103712Click image for larger version
ID:	7103713Click image for larger version
                        A was way runnier - like Araldite, B seemed coarser, C was less gritty etc - i think I ended up running in some A & then building it up with C - they are all hard as fuck.
                        This was after i hit them with a file -
                          Yeah the trick here is getting the surfaces clean.
                            Fuck the devcon JB weld shit, it all fucks up after a while. Seen plenty of cracked sumps and hydraulic oil tanks 'fixed' with it that last a week.
                            Silver solder aint silver solder, most of it is high temperature, you dont want to be heating your pan to 950c to get it to work; What you want is this stuff
                            https://www.jaycar.com.au/stay-brite...r-kit/p/NS3045
                            Low temp, propane torch will get it happening.
                            Drain the sump and clean the fuck out of the area with acetone etc and then solder over it.
                              Wait how small is the leak? You can also try peening it closed with a centre punch. That is another trick I have used before.
                              It would have to be a very small leak though and obviously will need access for the centre punch and to swing the hammer.
