Thread tapping - Cordles drill.
    What could possibly go wrong !!
    New product for Subaru requires all threads to have a tap run through them due to weld penetration required to pass their specified weld macro's (Weld creates a tight spot in the root nut).
    For the validation and test samples (and subsequent off tool samples) I have personally been running a tap with a battery drill prior to dispatch.
    Once this towbar hits production If I let them have it with a cordless drill driven tap.... they gunna fuck that up well and truly.
    Putting in the SOP a manual tap process is the solution but per towbar and side arm combo there is 14 root nuts in total to be tapped.................yeah as if thats going to be done/policed/checked.
    any idea's on an easy (for production) process to run a tap ?
      tapping drill + spiral fluted tap?
      https://www.allfasteners.com.au/fein...-drill-agwp-10
        Install taps before welding, then wind out when cool? Probably create more problems than it solves though.
          not a silly idea actually !!
            Originally posted by 080GMH View Post
            Hmmm. very interesting, Thanks.
              Would cause access issues with the robot.
                i know. any idiot can use it and it would be fairly quick and easy to do.
                  They have been around for a long time. Bosch also have an electric one and have seen various pneumatic ones around.
                    I never knew such a thing existed, need to do M12 threads, this Metabo one looks like it will fit the bill perfectly.
                    https://www.metabo.com/com/en/tools/...s-tappers.html
                      yeah the metabo looks like a good thing, well priced as well.
                        Have you seen the Flex Arm hydraulic tapping stations?
                        There s a guy on jewtube who got one for his "home" shop, looks pretty versatile and would mean an efficient workstation.
                        I'll see if I can find the video
                        Edit : https://youtu.be/hClkN7YmxNY
                          When I did my apprenticeship at ARB. They had a tap chuck/tool for the dress press that changed direction when load was applied to it
                          like this one
                          https://www.machineryhouse.com.au/T0...EaAgYXEALw_wcB
                          and just used a gun tap or spiral flute tap
                          I am guessing these a through holes?
                          '01 RS125
                          '01 CR500
                          '05 CR250
                          '07 CR125
                          '70 Mk2 Cortina
                          '80 1200 Ute
                          '12 Transit
                            Clock/anti rotation switch? That Metabo looks like it has a slide switch the same as my Ozito drill which is a PITA to use.
                              Gotta laugh.
                              This thread tapping exercise was known 6 months ago.
                              Started this thread 4 months ago in the knowledge production was coming and floated options in the morning manager meeting but was shot down hard by the GM about using powertools to run threads, I made the sarcastic quip "sorry for trying to make productions life easy, they will have to manually run the threads with a hand tap".... and left it at that.
                              Bit of a delay due to covid but 1s production run is underway (300 tow bars) with a massive push to have them in a shipping comtainer this weekend which will be a stretch but we will get it down.
                              then today I mention the 100% thread running that needs to be done to the GM who is push push push get them down and into a container.
                              Yeah... the shit has hit the fan as the target will be missed as "ZOMG WE HAVE TO RUN A TAP THROUGH EVERY THREAD WHY WAS THIS NOT KNOWN EARLIER:"..............
                              Tomoz I will be running a tap for 12 hours............ Thank fuck Friday I have off to go get the numberplates for my car.
                              And yeah thOr.... a thread tapping station with a flex arm is tasked to me to make it happen yesterday.....
