Reducing an M6 thread to M4.
    As it say on the tin,
    We have a product that current has a laser cut hex hole for an M6 Hexsert, A change in design has required the thread size to reduced to M4.
    We have a few hundred of these already made, welding the hole is not an option so before we scrap them am looking to see if it there is a way to the thread to M4..
    Ive searched googgle with no luck so thought the PF brains trust might have some suggestions.
    Can you drill the hexsert oversize and press/loctite a plug in to suit M4?
      Drill and tap the plug ?
        If this was a backyard fix, I'd get two washers to suit a M4 Rivnut and place them either side and use the Rivnut to clamp them in place. But, would depend on desired accuracy and wall thickness as it would add +/-1mm to the hole position tolerance. Presumably being M4, it's not holding a whole lot?
          Nah only holding a plastic fascia on a nudgbar.
          outer surface has to remain flush.
          Changed my search terms and found these on aliexpress.... only in brass or copper though so still searching.
Name:	nissan nudgebar thread reducer.jpg
            You need stainless?
            Not cheap:
            https://www.ebay.com.au/itm/262791917383
            or more expensive:
            https://www.mcmaster.com/97437A815/
              Originally posted by Shonky View Post
              You need stainless?
              Not cheap:
              or more expensive:
              perfect, thanks.
                Looks like you can get a M4 keysert with an m6 external thread.
                  I did find them in my searches, the M6 thread is .75 pitch... I need 1.00
                    Surely lathe work is cheap in Thailand?
                      The machine shops we use here are on par with the machine shops our parent company uses in Melbourne, cost wise.
