I am interested in doing one myself so and I see that its becoming popular- more so because for performance wise theres little downside.
Anyway I just wanted some discussion about the compressor flows and how it can work. I will use Stocky setup as that is im my view an excellent route to take.
So setup is.. Air> Turbo > SC > IC > Manifold
Please comment/correct on my points on these situations.
1) On idle/low throttle/vacum there is a 2-5spi spring wastegate that routes the air from SC outlet back to Turbo Inlet. Under load the wastegate is shut.
2) As turbo builds pressure the SC should be increasing this pressure at any time. Therefore SC outlet will always be equal or greater than the Turbo outlet/SC inlet, so then the manifold pressure will reach a max setting (e.g 1Bar) and there will be another wastegate set at 1 Bar which will progressively divert the turbo outlet direct to manifold inlet bypassing the SC. When fully open the SC is not underload and so small HP is used. (No clutch used due to pulley size issue/slipping/complications.)
3) Something I have not read about is looking at the comressor maps of turbos at low rpm when inlet pressure is high due to the SC, the SC might need more CFM than the turbo can suck in itself- also known as Choke, i.e the turbo is spinning at this moment in time at low rpm so only a small can be CFM be sucked in, just like sticking a small turbo on a large engine. Is this an issue for the SC?, to me you could say the SC is sucking air through the turbo and it will be ok but this means theres a vacum and its then the same as the choke on a big engine. So if this is the case (for a small section on the map) could you then have a vacum BOV or wastegate to open up under this choke condition and the SC will bring in its extra CFM from the turbo inlet? (So in theory youll get part of its CFM boosted from turbo and the other at 0bar). Then the turbo begins to spin up and give the SC the CFM it needs, comes back on its compressor map and so the valve closes. I guess this 3rd point (if valid) is an added extra for higher boost at low rpm...
What do you guys think? This is a simple but effective setup...
The great point is that you can get the biggest turbos you can find so max efficency is at max rpm.
Having a completely flat torque is what you can achieve with a twincharge, I added a dyno from a Mini thats twincharged, two runs, one before and after...
Thanks
Miles
