Turbo selection for a 5.7 V8
    i have a gt3582r on a 1uz and its on boost well before 3000rpm... ad an extra 1.7l capacity to the engine and the same turbo is stupid...
    i only used it on the 1uz as it was lying around not doing anything at the time...
    next turbo 1uz is going to cop a gt45 sized turbo...
      S400SX-72 ETT*
      bog warmer cheap because detroit spec. not going to explode like ebay china shit.
      72mm ind, 1.10 T4 83mm rear
      $649
      if the car is auto, its going to fucking spool instantly, why in the fuck would you put a GT35 on a LS1,
        You don't get response by connecting a giant ancient compressor to a small ancient turbine.
        You also cannot make an engine magically have a wider power band by using a ridiculously undersized turbo.
        You need to do some research on how a turbo works and how it effects an engines behaviour.
          So what you are saying is get a PD supercharger instead
            hes been told but didn't want to listen. GT35 with 1.06 but seems to think the housing is too big for a fucking 5.7L v8
            Woah there, relax tiger - someone's a little touchy eh?
            My question about 1.06 being too large was actually in relation to lysdexia's recommendation of a GT40. And it was just that - a question, hoping for an explanation behind the recommendation.
            And as perfect as the PTE6870 may be, I've already made it clear that's out of my budget.
            Dimi, the S400sx recommendation is an interesting one - I know nothing about them. Do you have any rough idea of what RPM that would come on full boost on an LS? I can't seem to find any online around the $600 mark though. Is this your turbo or do you have a link where I can get one for cheapcheaps? And when you talk about spooling instantly and being too small, are you referring to that S400sx or the GT35?
            JZK25, I freely admit I'm out of my league here in terms of knowledge. Hence me posting here, this is a small part of "doing my research".
            I'm not looking to make magically make the power band wider as suggested (thought I'm not sure if that comment was aimed at me, or some of the other suggestions posted so far). I'm well aware a low-spooling turbo is going to sacrifice top end, and I made it clear that I don't mind if it runs out of huff at higher RPM in my first post.
            As for getting response by using a smaller turbine and a larger compressor, I honestly thought that was how it worked (all other things like fins, bearings and housing design being equal). So if that's not the case, happy to be told I'm wrong. Just trying to learn here.
            Slides, thanks again for your info. I think you lost me a bit on the technical detail there though. If you're suggesting T66 over a T76, what sized turbine and compressor wheels would you recommend (in mm) and what AR's?
              A T66 is a T66, the original garrett specs are still searchable if retailers are calling different wheel major and minor diameters by they same name they are wrong. Each compressor in the T series refers to a defined induces diameter(and fixed associated exducer) likewise the turbines should be based on the garret spec sizes P-trim or Q-trim (or the smaller ones in that series that are not relevant here) i will note i have seen China turbines based on that series between o & p minor diameter but nearly all the big ones are P or Q i think? As above mismatch of compressor and turbine will set you back rather than help with spool, only thing it is likely to do is create bottom end surge on load which will shorten lifespan. As a very rough rule of thumb the compressor inducer and turbine exducer (both the minor diameter) should be relatively close in size.
                couldn't give you a number.
                Its not going to be the quickest spooling, its not going to be the most powerful, but it'll roughly do what you want and i'm suggesting it because you want to spend ebay china turbo money. There are far superior options out there for $2-3-4k
                pick your poison.
                http://www.forcedinductions.com/productsborgwarner.htm
                FYI i run a bigger version of this turbo with one of these ancient design truck spec compressor wheels and ancient design turbine wheels on a LS with a 3k converter its responsive as fuck and faster than pretty much every cunt here bar dale lol. But i'll wait for the nerds to tell me why im/its shit haha
                  Ok, the p trim/76mm thing is junk, forget it.
                  An S300 Sx3 with a large exhaust housing(above 1ar) and 66 mm compressor would work well as a responsive turbo on an LS1 but will probably top out at 550hp atw. A GT4094 with 1.19 housing would also work but again will top out at about the same.
                  It depends what you actually want the engine to do and what power you want it to make. A near std LS1 vs a big cammed LS1 is also two different things. The engines don't need to make power below 3000rpm because they have a gearbox that works and can rev pretty hard.
                    My vote is S366 for cheap and quick spooling. Have heard of a couple of cars making around 400rwkw at about 12psi (I think) with them. Of the top of my head, it should see about 5-6psi at 2500rpm.
                    Edit: see post #19 herehttp://ls1tech.com/forums/forced-ind...rner-s366.html
                      Put a 2500-3000 converter in your junk and it'll solve all your 'must spool at idle' problems. It will also make it accelerate faster than a school bus from a stop
                      Originally posted by RVK 355
                      Hold it flat cunt
                        pick your poison.
                        Wait you can buy them new for that money? Jesus that's a bit of a win.
                          Thanks mate, that's good advice. it's sounding more and more like a bog warrior will fit the bill. Engine will be near standard and 550HP is plenty for me.
                            My god that power curve is a thing of beauty. I'm in love.
                              Thanks Slides, awesome info. I particularly like the tip about matching in/ex on the turbine and compressor wheels.
                                * All price are in USD and exclude shipping.
