Wastegate spring vs boost
    I'm fairly new to the turbo scene. When i built my barra turbo a few people suggested i go to a 14psi wastegate spring in my turbosmart internal wastegate. I also went to a manual turbosmart boost tee.
    I understand the upgraded spring is to stop the internal gate blowing open. However. How do guys get almost double the psi?
    Say 7psi spring and 15psi at engine, or 14psi and 25-28psi. Without using co2 assistance to hold the gate steady
    Originally posted by 50RTD
    Loose rule is spring should be half the pressure you want to run, but many variables obviously
    Means well but is skittled
      External gate is like a poppet style, so pressure on the other side is reasonably irrelevant, on a flap style internal be pretty much the same deal?
      I've got a 16psi spring in my gate, and regulating it to 33 is no probs
      Sent from my Pixel 2 XL using Tapatalk
        I understand a dual port or external gate is different.
          The taxi currently runs one spring in the internal wastegate and makes just over 16psi. I've got two more springs to put in it (it originally came with three in it, but we removed two)
          Sent from my SM-G950F using Tapatalk
            Internal flapper gates I have seen are arranged so pre-turbine exhaust pressure will force it open, not closed. NFI about externals.
              yeah - walked out to the shed to check - essentially they hope that the surface area in the actuator is much larger than the flap - so a 16psi wastegate spring with no pressure being applied to it probably needs a fair bit more than 16psi against the flap (if 0 against the actuator diaphragm) to push it open.
              I assume they would prefer it to fail open than closed.
                You can do some basic maths on valve vs diaphragm area and spring force to get a rough idea but it relies on turbine/compressor match to engine keeping EMP:IMP reasonable.
                  Because the wastegate diaphragm doesn't see any boost pressure until the ECU opens the boost control solenoid.
                    My figuring also!
                      That makes sense. If the wastegate is bigger than the internal flap it will generate more boost
                        I run a manual boost t
                          You transplanted the factory loom didn't you? Why not fit a solenoid and have it tuned. You can always add a switch on the positive power wire if you only want to run gate pressure. Less likely to do the overboost on transition that manual bleeds tend to exibit and give a wider control range.
                            I have the loom there but factory boost solenoid was playing around, that's why we went boost t. Some say it's a crisper response
                              I haven't looked into the ford and holden reflash stuff but I'm betting there are a heap of base duty, PID and per gear tables you can tweak so it comes on a bit harder than a stocker with electronic control.
