2.2L SR20 turbo selection
    Hey cunts,
    SR20 I have has the 3540 with some bigger comp wheel by GCG, core has too much end float so I want to replace it. I have 3 options.
    GTX35 $2700 bolt in
    Put new core in the 3566 about $1100 bolt in
    Precision 6266 about 2700 need to model up dump drain etc
    What is the best option.
    3D scanning
    3D modelling
    Structural certification
    3 and 5 axis milling
    Depends. Are you reasonably happy with that turbo? Replacing with the same core saves retune too, assuminig its running atm
    Disclaimer: I may have no idea what I am talking about
      Yes it is all running, what I was after is say is the precision that much better?
      3D scanning
      3D modelling
        #donald #coalisbad #feminism #leftisbest
        Just trying to get a technical question some airtime
        3D scanning
        3D modelling
          Procharge were doing 9 blade turbine upgrades pretty cheap?
            Ben at procharge is also one of the nicest guys in the trade. Very helpful and knowledgeable.
              GTX3582. 3566 is old TO4Z compressor on GT35 turbine.
              If you are negro riche then get a complete GTX3584RS. Assuming you want more power.
                What sort of lag we talking going up to the rs?
                Also does this run the same turbine side eg will the dump bolt up or need to mod?
                3D scanning
                3D modelling
                  GTX3584RS wont bolt up, its Vband everything and the housings are not compatible.
                  GTX3582R Gen 2 should have the same turbine wheel as an old GT35R, which I think is the same as a GT3540, so it should be fine to swap the turbine housings and pretty much bolt on.
                  Maps are available on the garrett website but I dont know how to compare to what you have now. Should be at least the same or better power.
                    So I read a bit on the Garrett site, gen 2 gtx3582 uses same old exhaust housing, gtx3584 is all new turbine side so I am getting a price on that but I'm thinking a gen 2 gtx3582 is prob half smart as bolt on and prob same or more power. But I am tempted by the new 3584rs lol
                    3D scanning
                    3D modelling
                      Ok cunts well I went with precision 6266, my friend convinced me mind you he has a much larger PT at 55 psi on a SR20 and does 180 mph so we will see how this smaller one goes. He says to not be scared on the boost levels cos these things keep making your 10kw per psi. When it makes about 460 I'll stop winding in.
                      3D scanning
                      3D modelling
                        Well cunts cos I'm lazy AF I have chucks gtx35 coming and will bolt it on. So I might do some comparisons as I have the 6266 here as well.
                        3D scanning
                        3D modelling
                          EFRs never got considered?
                          I've got a 7163G (twin-scroll internal gate) on the way for my 2.2L 3SGTE.
                          Funnily enough, im buying it from Supercheap Auto.
                          GCG have the 7163 advertised for ~$3200.
                          I ordered it on Supercheaps website while they had a 30% off sale a few weeks back... came to $2300 :D
                          (they sell some Garrets too BTW).
                            Cant find any turbos on supercheap wensite?
                              https://www.supercheapauto.com.au/p/...gment=1&page=1
