Cheep w2a innercoola
    Hey dudes.
    We are looking at installing a water to air cooler setup on a car we are fucking about with.
    I've read a few builds (including Glens celica) which got heaps of info in them.
    Isn't a complete cheap cunt build but trying to keep things affordable for the basis of this project.
    I can't seem to get any sort of answer googling whether or not the ones of ebay are any good, or the cheaper ones are much chop.
    I've found a couple with a unit, pump and hoses for anywhere between 3-$600 on ebay
    E.g.
    https://www.ebay.com.au/itm/Premium-...torefresh=true
    Seems ok?
    It's going into a Corolla so the engine bay isn't huge and would like to limit chopping the front beaver for an intercooler IF possible. I think I can hide the heat exchanger up front and down towards the bottom which won't incur much damage with my grinder as a normal sized cooler would.
    Any other advice on this topic would be ace to.
    Thanks bros
    J
    BF XR6 Turbo - 2L Turbo TE - 75 TX Coupe - Atlas SS
    - PSN: rotacoupe
    I've done an ebay setup on my 4x4. My advice is to get a decent pump. I had two of the Chinese pumps fuck up in less than a month. They are cheap garbage. Ended up using a Davies Craig pump and its been fine ever since. I haven't had any problems with the heat exchanger, intercooler or inline remote filler neck which were all basically the cheapest I could find on ebay. Setup has been working well for 4 years. I mounted a small high velocity fan behind the heat exchanger and have that along with the pump wired to a switch in case I need to shut it down for water crossings or it drops the coolant etc.
      Thanks for that.
      I was talking to my auto elec mate and he said his mobs done a heap of them on 4x4s but he's never bothered looking into what brand/where it came from.
      From reading a few articles (and the details are super vague) is the pumps are a bit hit a miss.
      I'm happy to ditch it for a Davies Craig one if that's a common failure. If I have to spend a few dollars more on a reliable pump so be it.
      Yeah fan was always on the cards. I read a miata build which not much info but they all seem to go with a thermo fan on them to help.
      Thanks for the advice
      - PSN: rotacoupe
        Are the new Davies Craig pumps much chop though? They used to leak regularly out the spindle.
          The old ones the spindle seals would go if subjected to a vacuum, i.e. old school radiator cap with no overflow bottle.
          The "new" (the last decade) pumps don't have that issue.
          Bosch OEM pumps are the go though.
            One of theeeeessseee???
            http://www.sonicperformance.com.au/0...on-Pump/pd.php
            - PSN: rotacoupe
              That's the sort of thing, there are plenty to choose from in Euro cars.
              e.g. BMW & VAG heater pumps etc
                E.g.
                Seems ok?
                Send Foamy a PM here, that's his ebay listing lol
                The pumps in that kit are a good thing, he put some effort into getting them.
                  Flick me a PM with what you need!
                    Good to know we've got a PF supplier for these!
                    I need one to fit in an AW11 next year.
                      Ha! Excellent stuff I didn't even think to ask you :D
                      - PSN: rotacoupe
