AN6 vs AN8 vs AN10
    AN6 vs AN8 vs AN10
    There's a new Lolly shop opening soon and I need to get the Bedford there first!
    Changing from single in tank pump to twin in tank pumps because reasons.
    Currently has one an6 line that splits into two an6 for dual feed rail.
    I will run 2 an6 lines and probably two filters with the new pumps but will join them post filter before splitting off into the an6 feeds to the rail.
    Should I go 2 x an6 into an10 or will an8 suffice?
    Also thinking of maybe going up ftom an6 to an8 on the return but the fitting at the tank bulkhead is already an6 so think that may be a waste of time.
    Pumps will be 2 x dw400s
    Nope
    Keep the return small to keep pressure in rail.
    I run twin 460s in my surge to twin 6an (one has flex fuel sensor) to 8an with fuel filter, single entry 8an on rail, 6an return to surge.
    I have single 6an feed from fuel tank and return
    Originally posted by 50RTD
      Im running two -6s into a -8. Two -6s (by area) are very similar to one -8
      Are you staging the pumps?
        The return line should be able to handle 100% of the fuel flow without creating crazy pump head pressures, modern electric pumps are not positive displacement but you dont want some tiny return hose.
        Single -8 feed and return will be plenty.
          Thanks guys.
          Not staging the pumps at this stage.
          Nope
            Not many 8an full flow efi regs though without spending bulk coin. So there is always a restriction, even to get it to 58psi
              Yeah I reckon -6 return is fine
              Im running the second pump only at the track to make it easier on the electrical system....until I forget to switch it on and lunch a motor
                Hobbs switch or hallaltech can switch it on at say 5psi boost. Or just run it all the time off two relays
                  2 relays are already wired up ready to go.
                  Might stuff around later with staged but more to go wrong.
                  Nope
                    Correct, why I run mine all the time
                      dual DW400s? I look forward to seeing this 1000whp van.
                      Oo___oO
                        Already got one so makes sense to use two of the same
                        Nope
