Welding Steam Pipe to Stainless Steel
Ok im making a steam pipe turbo manifold but i got the collect made in stainless steel. Will it be ok to weld the two together? I'm pretty sure they'll weld fine but i'm worried about the different expansion characteristcs possibly causing the joint to crack.Tags: None
i've done stainless to mild with the stick welder, although not in very high heat applications.
my advice would be to use stainless rods to do it. i reckon it'll be fine.I am a Spinal and Sports Physio based in Flemington, Melbourne. Insane discounts for PF members!
www.showgroundsphysio.com.au
www.neillsbikefit.com.au
I've already made two of the runners and have all the steam pipe bends. I was going to copy the stainless merge collector but found cutting the angles too difficult so just wanted to weld the one i have on since its made perfect.
I"m using stainless rods with an ARC welder. Same way i did my intercooler pipes. Actually i find welding with the stainless easier than mild steel.
yeah it flows on nicer i reckon. go for it, if it breaks you can make another, better one.I am a Spinal and Sports Physio based in Flemington, Melbourne. Insane discounts for PF members!
i've done that a fair bit, no worries. stick welded using 1.6mm stainless rods and like 40 amps. it requires some specific techniques to work properly but it can be done.stainless pipe with mild steel flangesI am a Spinal and Sports Physio based in Flemington, Melbourne. Insane discounts for PF members!
309 wire( you can get electrodes as well) is used to join stainless to mild, pretty much all grades. We use it join 341 to 2 1/4 chrome among others, passes radio and 3000 psi service all the time.Originally posted by willsy01I don't know what the five-0 would charge you with......but PF will charge you with "failure to disclose an awesome piece of closed road" and have the word cunt tattooed on your forehead.
