One for 308 fans.
    Pacemakers for VH with VN heads, unfortunately you can't fit 4 into 1's in a VH, but 1 3/4" primary 4-2-1 pacemakers will work well.
    230HP (195 morosso), is all that is needed to run 14.5's in a full street VK (3000lbs).
    You could get that with a stock engine + crane 276 cam, good headers, edelbrock performer & 650DP holley.
    Cheers
    TK
      TK, wouldn't the std manifold, with the sharp edges in the plenum blended out, and rejetted std Q'jet be enough for a mild combo like that? (and be considerably better on fuel than a DP Holley)
      -Mahatma Gandhi
      Indian independence leader
        Quaddy is good, but an asshole to set up, holley can be tuned by a monkey & is easy to retune when engine improvements are made.
        Stock manifold would work ok, but most of them are badly corroded - may as well get an edelbrock.
        Cheers
        TK
          try PH5700s, 1 3/4 primarys to suit VN heads into VB-VL commodores
          http://www.youtube.com/watch?v=Jkgt38KRZ2c
