Replacing intake cam with US cam DIY tips
    Yeah you can be a bit rougher with shim-under stuff.. not that you should. lol
    But like TK said- Good fuggin luck taking much material off with a stone on the big shim over ones!
      Hey luke,
      Is the ad in your signature the laser cutting guy near your work? I need some exhaust flanges laser cut for my ca18, have cad file and engineering drawings.
        Don't you know how to use PMs? Noob. Yes thats him. Call or email me.
          Damn it. I take it you must remove the thin pressed steel backing plate that goes behind the cam gears to get the cams out? That sucks because I only unbolted one cam gear since I was only changing one cam..
          10.83 @ 125
          Originally posted by cracka
            Shit getting the old one out was easy. Even though I had to put the other cam gear back on to undo the other one it still only took about 45 minutes (I already had the cam covers off though).
            With the cam seals. Do they push in like the crank seal? I don't have a new seal yet. Can I put the cam back in and push the new seals on from the front like with the crank seal? I may as well fit a new seal to the exhaust cam too.
            10.83 @ 125
              yep you can push them in.
                you will need sealer under the first cap btw , otherwise you'll be leaking there.
                  You mean just seal the mating surface between the cap and head? Loctite No3?
                  Also I pulled a bucket and shim out to take a look then put it back in. Will that have stuffed anything up?
                  10.83 @ 125
                    yes.
                    no.
                      Sweet
                      Just need some seals now. So bearing shops are the go instead of Toyota hey for saving the $$$. Ya reckon CBC at Kingsford smith drive would be a good place to look?
                      10.83 @ 125
                        yeh they will have them.
                        i got the front main , rear main , cam seals , and a couple gearbox ones from memory all from local bearing mob.
                          Sweet. Did you use some sort of loctite on the cam cap bolts as TK suggests? Will a film of engine oil on the new seals be all that needed before installation?
                          10.83 @ 125
                            the fsm dosent call for loctite , just get yourself a torque wrench , 14 ft-lb for those bolts.
                            bit of oil on the seal lip is cool , make sure the rest is dry though.
                              just use common sense when tightening those down.
                              keep winding the bolts down evenly and turn the cam some every so often and you'll be right.
                                Cheers mate. I'm off to try and borrow a torque wrench and some feeler gauges that aren't rusted together. :p
                                10.83 @ 125
