Won't start when hot
    Your earth should be as big as your power cable. The smaller earth will limit what you can draw. So is that earth wire running all the way back from the starter as well?
    Originally posted by My mate Nathan
    "Boob is almost as good as cunt"
      Originally posted by oldcorollas View Post
      did you scrape off enough paint to make good electrical contact between the starter motor body and the block
      got an infra-red temp gun?
      There's no paint between block and starter. I have a cable running from each starter bolt. One goes back to the batt (can see in the pic), the other runs forward about 1 - 2 feet and is earthed on the chassis itself. There's also two other earth cables one off the block to chassis and one off heads to chassis.
      Don't have an infared gun. Never had the prob with the old engine. Weird. Even the old starer carked it when it got hot with the new engine. Same block and everything but it didn't even click, nothing happened at all.
      Yes. See above. Its not the only one.
      2004 Nissan El Grand rape van
      2007 Suzuki SX4 - Ski Mule
      2005 WR250
      + 2 trailers and a caravan.
      I finance the RMS
        hmm.. silly question time...
        checked the solenoid trigger wire and it's connections? it's not about to fall off and not getting enough current to pull the gear out?
          trigger wire is via a relay ?
            I have had issues with Alarms and immobilisers not allowing enough current to the solenoid wire, I have installed a relay and this really helps especially when the engine is hot.
              If it does mesh it turn a little (sounds weird) but won't turn it over properly
              Is this sound like the starter spinning without engaging the engine?
                Would the battery isolator switch make a difference?
                2005 WR250
                I finance the RMS
                  if it has poor contact and is heating up when trying to flow 100 amps... but even then, it should try to start once when hot.. and subsequent times it would be difficult..
                  if it never tries to start when hot, then something is getting hot from the engine running, and that could be the problem.
                  small wires etc are more issue after you try to start for a few seconds and the wires heat up, and then start to cause a problem...
                  hmm... exhaust follows same route as wires?
                    Nah the isolator is right at the back of the car, it doesn't get hot at all, just wondering if it could affect the power flow much.
                    I'm running a second power cable and spacing the starter down a bit. If this doesn't fix it I give up.
                    2005 WR250
                    I finance the RMS
                      New theory: Took the pipes off and watched the starter while someone else turned the key and the gear is just hitting the flexplate square. The clearance is fine and its dead cold. The flat part of the starter gear hits the flat part of the ring gear in certain positions. Fark.
                      2005 WR250
                      I finance the RMS
                        Told ya :D
                          Back together and its doing it worse. Its that but something else too. Fuck this I'm putting the old starter back in.
                          2005 WR250
                          I finance the RMS
                            Old starter back in. Works ok, not the best. It didn't work when the car over heated last time but hopefully with the thermal protector and coated headers it lasts for a week or so until I can rego the thing.
                            2005 WR250
                            I finance the RMS
                              your pistons are too big :p
                                same thing happening to my sisters car...
                                electrical problems are farked!
                                Another useless post for PF by bthology
