valve hitting pistons may have caused a spark/pre ignition or just a sharp edge/hot spot in the combustion chamber that allows pre-ignition to happen and blow the gasket.
to blow a gasket like that on an na engine, something is wrong, either a really high static compression ratio and low octane fuel or possibly mechanical.
is this engine running kalmaker? should be able to monitor knock, although it may have been disabled, they tend to be rather sensitive and can pick up noise in general, so it may have been fiddled with.
best of luck anyway.
Auto Electrical Accessory fitting in Brisbane!
