Wanted: Toyota 20V expert Sunshine Coast
    Dont make house calls do you??
      Nope.
        I do $500 call out fee then $150 per hour or part hour
        fixed
          I tried that, seems to be fine in that respect
          Originally posted by JayVee View Post
          If you keep the ignition switch in the start position after it starts, does it keep going?
          In other words, when you start it don't take the key back to the ign position for a short time....when you do this does the car keep running for that short period?
          Had a similar fault on my old KE55/13BT and I'd wired the power up wrong and it was only getting power when cranking.
            So it keeps going when you hold it in the cranking position?
            If so your running your igntion 12V from the wrong source, find a new constant 12V source that (when the ignition is on that is), and see if she runs.
              No it does exactly the same thing as before
                do you have a fuel pressure gauge? I'd like to eliminate the possibility of the fuel pump cutting out.
                  Yes fuel pressure stays constant at around 34psi
