Originally posted by Cplus
View Post
Aluminium Exhaust?
Yuh, anything that survives at those sorts of temperatures is not based on metallic aluminium. Titanium based alloys maybe - but otherwise anything that has lots of Al in it will probably have it as Al2O3 - plain old alumina, which is the main component of refractory materials.Originally posted by bugleThe non GTS's were gay
inconnel alloy maybewww.markpakula.com
Originally posted by Com_VC View PostBill: Got any pics of the inside? Also is it filled inside? I cut open apart a muffler before and it was filled with this hair like stuff..."Where can we get hold of a Vincent Black Shadow?" "Whats that?" "A fantastic bike," I said. "The new model is something like two thousand cubic inches, developing two hundred brake-horsepower at four thousand revolutions per minute on a magnesium frame with two styrofoam seats and a total curb weight of exactly two hundred pounds."
Bob - its a perforated tube straight through in a bigger can, then it has fiberglass matting wrapped around the perforated tube.
Usually just pop riveted the outer can to the ends. Pretty easy, i shortened the exhaust can on my R1.Mad Cunt
Cut up some end plates for the muffler today. They are out of some 5mm aluminium plate.
They are 194mm 0D and will fit inside some 200mm 3mm wall thickness aluminium pipe.
Need to roll up some 20mm edges tomorrow and weld them on to the ends. Just so I have something I can rivet into.
Just got a few questions.
Not 100% sure on the length, is there some sorta formula to work this out? I was sorta thinking 400mm long.
Where can I get some perforated aluminium tube? Need it to be 3"
With the riverts, do you need to apply some sorta sealant along the end plates or will all the rock wool, fibreglass matting or whatever seal it all up pretty well anyways?
Thanks
http://imajr.com/11112008-1279410
Originally posted by S_E View PostI think you're onto something here, watercooled exhaust!
I reckon alloy would crack like a mofo unless you really knew what you were doing. Just use S/S or mild and take the back seat out, much easier.Tow car/camping bus: 2011 D40 Navara ST
Bumping this up.
Would it be practical to construct an entire exhaust from Titanium? You can buy mufflers fairly easily but I was thinking of trying to source some tube, bends and/or donuts (if Titanium ones exist) and welding up a system including extractors. Would I be better off just getting a set of extractors done in stainless (say to the end of the gearbox or a bit further) and then titanium for the rest? I'm really motivated by the idea of saving a bit of weight.1971 Mazda 1300 Estate Deluxe 1500cc Twin SU - 1979 Mazda RX7 12APP - 1994 Mazda Familia GTR - 1973 Mazda 1300 Wagon
