Apexi AVC-R Vs. GReddy Profec
    well all i got it all fitted and tuned by cypher. and after a couple of hours on an open country road late at night........it is running perfectly.....i cannot recommend them anymore. it has increased bottom end response and "feels" quicker. although it MUST be tuned properly in 3rd gear.....otherwise it isnt accurate.
    it was tuned a bit in perth by cypher in 2nd gear....it was all adjusted and running fine. in 2nd it was set at 14psi boost and when we hit third later that night...it went up to 1.51 Bar.....22.3psi.......so make sure u re-tune it when u have the time!!!!!.....or put it on a dyno.
    all i can say is that im one happy chappy :D
    When the Clutch Drops The Bullshit Stops
      Road tuning at part throttle/cruising is a good idea to sort out any glitches that were missed on a dyno (rare but it happens) as long as speed limits are followed. Not everyone can get their car onto the rollers all of the time, but you have to at least get to one when the power levels are up and speed becomes a concern.
      Glad it worked out for you boosted, just make sure that the boost level doesn’t sky rocket. Overall the avcr is good for rpm boost though you might get the occassional boost spike when shifting hard on the gas from 1st to 2nd.
      Take it easy
