GTSBoy :- I Was thinking along the lines of insulation, but a water spray might be a simple test.
Dale :- The Vacuum booster won't fit in there with the 2j.
I have stumbled accross a thread where a BMW tech had the same issue, did the following :-
-Rebuilt both front calipers
-Flushed fluid, and replaced hoses
-Replaced pads and rotors. It needed them anyway
-Changed Pentosin (this is the fluid in the resevoir that later models used instead of trans/PS fluid)
but unfortunately the thread doesn't contain a resolve. Another thread talks about no change after replacing his hydraulic booster with a new unit.
If I can't correctly ID it over hte next week or two, the MC will be replaced along with the hydraulic booster.
