Originally posted by Mr Ed
View Post
Talk to me about flywheels
depends on the car setup. sometimes a heavier flywheel can have a positive effect on your launch.Originally posted by ar3nbe View PostOk, in terms of real life, quicker down the quarter ?
ref: rigoli awd manual drag car, they changed from a light to a heavy wheel to get the tyres turning off the line (if my memory serves me correctly)Pest Control - Brisbane, Gold Coast, Ipswich and South West QLD PF discounts apply.
Cheers, what sort of clutch was included in that?Originally posted by bahaimus View PostBased upon very rudimentary information, Direct Clutch gave me a $1500 ballpark figure for flywheel and clutch. I take my engine and box to them and they make them work together.
It depends of course upon the clutch that you choose to use and how much torques you're going to make.
Im aiming to get a custom flywheel made so I can use off the shelf GM/Ford clutches in my 2JZ/T56 combo, hopefully overall this will keep my costs down (as falcodore clutches are a shitload cheaper than Supra clutches)#WHOTW award winner #blessed #susanalbumparty
As others have said, Id expect it to be more useful in a track car than a drag car.Originally posted by ar3nbe View PostOk, in terms of real life, quicker down the quarter ?
It lets you put power down quicker at the expense of low speed drivability. I guess its similar in drivability to having an unsprung cunt of a clutch.
I was once told that a lighter clutch gives you more power but less torque, I have no idea if this is true or not (I tend not to believe the 'expert' that I heard it from due to alot of other bullshit I was told by him)#WHOTW award winner #blessed #susanalbumparty
Non specific at that stage.Originally posted by Mr Ed View PostCheers, what sort of clutch was included in that?
light flywheel seemed relatively shit in my brothers sr20 pulsar (my opinion from observation only)
light flywheel + huge cams with not much torque down low = almost stalling unless you rev the fuck out of it, modifed n/a + high revs required for take off = loud as fark even with muffler after muffler in pipework until no more would fit.
i guess a track only car this would all be a non issue.
what i'm saying is i would take drivability over a bees dick performance increase at the track.
Lightweight flywheel is one of my favourite mods. Extra power at the wheels (because there's more torque) without even trying. Also lets the engine drop revs quicker during manual gearchanges. I believe most complaints about the 1.8l mx5 being not as engaging as the 1.6l is because it has a heavier flywheel and doesn't feel as responsive.
The problem with you bro's engine was more likely due to the inlet manifold - I'm guessing it was a plenum type?Originally posted by RB30-POWER View Postlight flywheel seemed relatively shit in my brothers sr20 pulsar (my opinion from observation only)
And on the track it makes quite a lot of difference.
The extra torque is zero. Same as kw ... zero.Originally posted by stb View PostExtra power at the wheels (because there's more torque) without even trying.
The only difference is rotational inertia.
I paid <$450 for my lightened flywheel, but it is an off the shelf jobbie.
Ed, like i told you before you can get the Supra clutches resplined for the Falcadore box for about $20more, i think they are actually a Nissan clutch.Chris
Yeah Ive been looking into the options though and Im worried about using a supra clutch as then I have to fuck about with clutch forks running through the A340e bellhousing (or at least I believe so??), which sounds like it would be alot of effort and require skills that I lack.Originally posted by takai View PostEd, like i told you before you can get the Supra clutches resplined for the Falcadore box for about $20more, i think they are actually a Nissan clutch.
Im probably just gonna use a Tilton concentric slave (~$200), stock A70 master cyl, custom line, some form of off the shelf GM/Ford clutch & pressure plate and whatever flywheel I have to in order to make it work.
Or can I just use a 2JZ-GE clutch/flywheel/pressure plate with the concentric slave cyl?#WHOTW award winner #blessed #susanalbumparty
