direct clutch turn around is getting alot better atm....
Choosing the right clutch
You will need the pressure plate and the drive plate if you want to use the V160 clutch. Can't mix and match, the W58 clutch is a different diameter.
Yes the V160 clutch is a pull-type arrangement, and this is part of the reason it's much better than the W58 clutch (read: arseloads of clamp).
Sounds like it might not be an option for your setup. In which case, button clutch for you. Have fun and try not to obliterate your drivetrain.
Norbie!
Multiplate clutches put a lot more shock through the drivetrain so they can help you to start breaking axles, diffs and gearboxes too. I am a big fan of ceramic sprung button single plates if you need to drive them on the road. My race car uses one and is very reliable and easy to drive. Good thing is the can also slip a little which is a handy thing.A slow day at the track is better than any day in the office.
We get one day turnaround out of them on most jobs.Originally posted by tim510 View Postit could not have got worse...www.DRIVENFX.com Performance Engine Building, Auto Electrical (Wiring Looms, ECU Installs, Diganoses and Repair), Custom Automotive Electronics, Car Preparation, Car Setup, Trackside Services,
PM me for more info
And alot of stuff he says is total bullshit.Originally posted by stockymcstock View Postcall jim berry and ask him. prepare for a long conversation but you will eventually get the information you need
Single plate ceramic with a decent pressure plate will do you (either mod the stock one, or get a new one).
Unsprung clutch plate if you want to be a real man about things.
ps: dont' be a jew. doig things shit costs heaps more than just doing it right, because you ahve to do it shit, then do it shit a fwe more times, then realise you were wrong and do it properly anyway... just do it properly and it's done and you don't have to worry about it.
the moer things you half do, the more likely you are to bail on the project... i know from experienceOriginally posted by 350stato100% agree with Shifty
The pressure plate im using is a Toyota factory item, no idea how much clamping pressure will be possible but I'll see what the clutch guy can do.
Im not using all cheap shit, only the things I can get away with. Im not going to throw countless amounts of money at something unless I need to. The cheaper it is, the quicker I can finish it
I do agree with you though.....Ive done many many things on this car more than once. 2 intercoolers with custom pipes, 3 exhausts, 2 battery relocation jobs, 3 airboxes, 3 fuel pumps.....and its been off the road the entire time.....but at least Im still going!! :p#WHOTW award winner #blessed #susanalbumparty
