Anyone played with cams on a CA18DET?
    I also checked traction in 3rd gear with 225 Kumho V70As. This seems to be a new problem.
      wat cams did you end up getting.
        I just put the original exhaust cam onto the intake side and fitted another exhaust cam.
        Matt
        I do not like V slicers.
          Matt Spry tuned the car again last Thursday.
          Changes from the initial tune were a spare CA18DET cam fitted to the intake side, Growly CAS mount and some Growly adjustable cam gears.
          12 psi = 155rwkw (was 143)
          15 psi = 164rwkw (was 156)
          18 psi = 173rwkw (was 162)
          20 psi = 183rwkw (was 177)
          Peak power is still around 6300rpm.
          Matt ended up retarding the exhaust cam 2 degrees and advancing the intake cam 6 degrees.
          Overall a nice little upgrade.
