Which Wideband Sensor ver.1
    Originally posted by BMWTurbo View Post
    Most WBO2 sensors can connect to A/M or factory ECU's.
    If the microtech can accept a AFR input your laughing. You jsut need to cinfirm if it's wideband or narrow band as per earlier factory ECU's
    I had an o2 sensor on there before - but Dale said its useless cause its narrowband (i was new to all this back then) - so I fucked it off with the new exhaust etc... The microtech used to show AFR's - in narrowband though.
    Im pretty sure it should accept this ok, and failing that, as a tune only thing it should be ok... Still good.
    In fact, do I recall dale selling these on here somewhere?
    Originally posted by psssi98
      well i used to sell them...
      ive got one to send back to get checked as it has read 9:1 since brand new..
        As promised it arrived today Now booked into CHE for fitting :D
          fark that's the easy way out, i had to build some of mine, big job but worth the savings, they may be cheaper now pre-assembled anyway.
            $256 + postage mate, you can't argue with that
              you're fucken kidding! when did they come down to that sort of price range??
              John McKenzie
                Comes without the gauge for $29 less, but i figure the gauge is a good visual indicator for tuning. Costs about the same shipped to your door.
                Edit: very cheap on ebay, $250 delivered: [ls[/url]
                i got mine from my wholsaler in the US for $218 posted.
                run the narrow input to teh ECU and the wideband to the gauge.
                i had it wired to the +12v on my ECU, but engine started cutting out randomly.
                realised that the current draw was too high and found another 12v switched and has been fine since...
                  Originally posted by 10sec_rx7 View Post
                  you need to get the input setup to take a 0-5v input
                  you can change the output of teh LC-1 cant you?
                    I just bought one of these as well with a chip + programmer to tune the AU yoot.
                    It works out to be $380 for the wideband including a display.
                    www.tiperformance.com.au
                    Maverick - gone
                    Turbo AU Ute
                      Originally posted by UZZ31 View Post
                      Only problems ive heard with them is you need to makes sure you have a good earth and install them exactly as per the instructions or you can have problems
                      Like me .
                        Zeitronix also make a good piece of kit, they are all pretty much equal now days.
                        I always find it funny to run them against other dyno o2 sensors. The are all almost spot on.
                        Jason Broadhurst
                          I would trust my techedge before i trusted a dyno o2 sensor that most likely has a million hours of use on it and hasn't been replaced, besides if you mount it pre-cat it's going to be way better for tuning in that location.
                            Who runs cats now days :D
                            I compair tail sniffer to tail sniffer, and have also compared tailsniffer to dump pipe and its all so similar its not an issue.
                            Jason Broadhurst
                              your so wrong there is it not funny...
                              i dont trust any cheap widebands... seen way too many of them be more than a few points out... they are good for referance but anyone who tunes a car with them is playing with fire.. espically PLX and innovate..
                              most good dyno shops will change the sensor when it needs it., the good quality meters tell you when there is something wrong, ie the heater is fucked or you can tell straight up when they read lean..
                                back when i started messing about with the techedge lsu sensors most dynos were still using the crappy (in comparison, unless you want to tune leaded fuels) lsm11 sensors. i would hope most dyno operators have the later sensor type now days, but that was a few years back.
