what engine for go fasts?
    or as Turbo351 said LS1 if youre not concerned about keeping it all-Toyota
    Seeing how tight these two options are in the engine bay can you even fit a JZ?
    1UZ+1NZ...
      Originally posted by nash View Post
      brapbrapbrarapbrapr
      + brapbrapbrapbrapbrapbrapbrapbrapbrapbrapbrapbrapbr apbrapbrap
        been done before, but without giving any fark for corners
          Why would you want to? When you can fit an all alloy 3.5L V6 with decent power for a car like the sprinter standard that actually weighs less than a supercharged/turbocharged 4AG, I have no idea why you'd want to put a 2JZ in one unless you wanted to build a drag car.
          Originally posted by Marv
          She most likely doesn't bathe, thinks basket-weaving should be in the Olympics and has a vagina that looks like Dumbledore's beard.
            ^ well yeah that was the point, seeing how tight it is for an engine 4 cylinders long i was doubting you'd get an inline 6 in without major work, and for little/no benefit compared to other options
            1UZ+1NZ...
              http://www.toymods.org.au/forums/sho...t=21137&page=4
              Looks like it might need a Ford Boss style bonnet though haha.
                how about a 1mz ? the job done on the celica could be replicated here. it probably wouldn't fuck your handling too bad either.
                Originally posted by Skompa
                  Spoon engine
                    Originally posted by spunkrat View Post
                    A bloke up here put a 1UZ in his AE86 with much success. The thing was a weapon and it was standard motor with extractors and exhaust. He has since sold that car and I believe is putting a turbo 1UZ in his current AE86 coupe shell. Do that.
                    Josh had a set of ITB's on that engine from NZ along with an adaptronic, it put out 200kw atw. He's since scrapped the turbo 1uz coupe project.
                    I'd also like to see a 2grfe done properly.
                      Ah yeh my bad, forgot about the ITB's. Still, it was basically stock, no big cams, no high compression build etc.
                      Just for the record, the one we are talking about is the red one in the video at the top of the page.
                          +1 for the 1UZ vote
                          Han, Enter the Dragon
                            1UZ or LS1 all the way.
                            Hr under construction
                              4g63 ?
                              Engine mite cost a bit more, but its strong, fuck easy to get power out of and cheap to rebuild.
                                If you want something different and interesting what about a VW 'W6' from the R32. . .
