2 bolt is fine for 3" flanges. Flatten the surfaces, pull them together evenly and use good gaskets.
I find that flanges distort a lot less when hit with decent amps with the MIG rather than fluffing around. Hit the plate with 90% of the heat and do the whole weld at once and they dont buckle as bad.
If they are pre turbo flanges then they need steel sheet gaskets and machined flat flanges.
