Toyota 1GZFE V12 thread.
    Yes I know there is one on Toymods but I don't care.
    We got our two engines yesterday so I started ripping bits off mine and measuring it up.
    Some pics.
    Pealing back the layers of inlet manifolding revealed severe gheyness.
    That's one way to detune it. I need to send a pair of these to Norbie so he can chop out the filled in bit and unleash horsepowers.
    With all but the bottom manifold off.
    This is a very compact engine, it's significantly narrower than a 1UZ.
    Rough dimensions are 800mm from bellhousing to water neck(750mm to the front pulley), 700mm from sump to manifold top, 600mm from head to head.
    Will add more as I pull shit off it. Plan is to wire the E1280S to it and get it running in a frame on the ground.
    Tossing up between fitting it to an IS200 or R32 GTR.
    *subscribes*
      Would it be much fucking around to ditch the standard inlet manifold gayness altogether? Seems like fuckloads of shit that doesn't need to be there, not to mention keeping it even more compact....
        *subscribes*
        Yes!
        Originally posted by TK
          60 deg V helps, making it approx 100mm narrower (UZ is basically a 700mm cube ).
          They don't have the toughest rods so stay a bit conservative if you decide to boost it
          GT8
          1UZ Celica
          1.07 flat Wakefield Park
            awesome. what tranny is this going to be backed by?
              1 vote: IS200/300.
              I used to work at Lexus and I saw an IS300 with a turbo 2JZ + 450hp, fell in love with those cars, they make a great platform for an engine swap!
              '02 Nissan X-Trail GT-L. Disco Potato .86 rear @ 0.7bar(10psi), EMS stinger, LC-1 wideband, FMIC, 440s, 3" zorst, gauges n shit... bout 280hp @ all four - some of my own tuning. No Powerchip. Coming soon: Tial MV-S sexternal gate, FPR and 0.9 bar, coilovers and slammage.
                mark IV supra with twin GT42Rs
                  or KE20 corolla
                    Is there any rational way to explain the manifolds?
                    I mean torque is preferred over power in these luxobarges but surely a reasonably close sized runner would be much the same in an injected engine?
                      hmmm same bore and stroke as a 1jz
                      http://www.lextreme.com/V12.html
                      List of cars goes here
                        The manifold is fairly easy to change, same way top secret did it but I will probably use a pair of DBW throttles instead of cable throttles.
                        I notice the rods appear fairly small but having double the amount of them to share the load should help.
                        I haven't decided on anything regarding transmissions or anything as I don't know what it'll go in yet.
                        Sensible says IS200 with some pipes and no turbos. Stupid says R32 GTR with twin 35's and T400.
                          My vote is IS200!! Interested to see how this thread goes.
                            some good info here
                            http://www.lextreme.com/forums/showthread.php?t=9809
                              what's the ret... uhh capacity of these motors?
