closer to $250 after adding the master cylinders to the shopping cart
PEDAL BOX - current flavour?
You'll notice a hell of a lot of difference. The pedal effort is usually quite a lot higher though there's many variables of course.Originally posted by boostin31 View PostHow would a floor mounted pedal box go for street use? Like doing away with the standard brake master and booster? with the right pedal ratios etc would you notice the difference between boosted and unboosted? besides the pedal feel?
FWIW I'm putting one into the Fraser right now.
Which model do you have?Originally posted by HoonBoy View PostI have one of these setups and whilst it "works" it is on the budget side of things and you can tell the difference with the good ones. I was playing around with an AP floor mounted pull setup earlier today, very very nice and I would look seriously at one if it was within my budget. (about $4,600 for the base pedal box plus master cylinders etc.)
Not many droopz. Wouldnt be hard to rig one up though, or use a pressure switch off the front circuit.Chris
