Engine stand to engine bolt strength
    just use really wide zipties.
    Originally posted by tim510
    More rabbit less turtle!
    http://www.Tutter.net
      i use 10.9's only because there all i can find in the old bolts draw the right size for my engine
        I reckon a clevo with cast iron heads would be on the scale of heavy, near the top, I just used some black grade 8.8 fasteners random length with some big nuts as washers.
        Don't stress.
          Originally posted by Greg Rust
          Don't stress.
          I'm starting to see a common theme emerging here ...
          :D
            Stress your fastener, not your head.
              Just be sure they engage as much thread as possible, especially in an alloy block.
                I think I re-used the old nissan head bolts to hold up my CA
                PF Gamers List
                  Don't stress.
                  I was always more worried about the flex in the stand - used to have a prop under the balancer when rolling it cross country to keep it from fatigueing at the bottom joints...
                    I welded nuts to some studs and rounded off the hex so they fitted inside the sleeve on the engine stand and used normal bell housing bolts into them. It looks as dodgy as it sounds.
                    97 Express van 4G63 compound Turbo Tdo5/HX40 @ 34.7234psi.
                    Gone--
                    93 GSR 1.8L 406whp 11.6@126mph
                      Originally posted by xm-221 View Post
                      I've got Holden 6cyl head bolts holding a Clevo and a 250 crossflow on the engine stands at work. Use whatever you can find, the higher the grade the better though.
                      what kind of engine stand do you have the clevo on? we tried 2 different stands when attempting to do a rear main on the boat motor. even tried welding steel onto the second one to stiffen it and it was still creaking and groaning. we gave up and took it to the engine builder to deal with.
                          Luxury.
                          Mine's got bolts that have been cut in half and welded back together with extensions to make them long enough.
                          Opened thread to say this. I used some 8mm round bar to extend the bolts in mine...
                          Used to be TehEkHo
                            I amnot even going to start correcting this.
                            Originally posted by 350stato
                            100% agree with Shifty
                              I'm
                                Photo of one of our half-arsed bolts for lols.
