Originally posted by Terribleone
View Post
shortening a borg warner.
the vn one i cut today was 4mm at best. pipe cutter did it easy. so when everything is open tomorrow i'll see if i can get some solid and hollow bar to make up an aligning jig. thanks dude.Originally posted by SkompaThe throttle linkages jammed on the CDs in my old Triumph 2000 and stuck it at WOT.
lashed out today and bought 2m of 2 inch round bar. then a bit of hollow bar to make the other bits. the 2 inch round bar seems like massive overkill, but it was in stock and worked with the hollow bar in stock so i grabbed it. should see it monday. where is a good place to go in adelaide to get the axle shortened ?Originally posted by SkompaThe throttle linkages jammed on the CDs in my old Triumph 2000 and stuck it at WOT.
Should have started with r31 skyline diff, more ideal length for what you are doing so pinion would end up more centre, 28 spline, same 4 stud as the front, same diff centre.
Once you weld it together you will still need to finish straighten the housing with heat of some kind. Strap some 2m long steel to axle bearing faces of housing to exaggerate any difference, and measure in between them to check for square.meh
What size bar did you use, and is it just mild steel? did you just spin the spacers down out of alloy? Looks fucken great, might do a borgy for the express van.Originally posted by Gassed250 View Posti cut one down, its easy as piss
its all in here
http://www.xfalcon.com/forums/index....age__hl__sigma97 Express van 4G63 compound Turbo Tdo5/HX40 @ 34.7234psi.
Gone--
93 GSR 1.8L 406whp 11.6@126mph
Said it before and will say it again, top job thereOriginally posted by Gassed250 View Posti cut one down, its easy as piss
its all in here
http://www.xfalcon.com/forums/index....age__hl__sigmaI own a two and a half litre Commodore
i've bough the steel to make a setup like gassed250 used. if i cut the same amount out of each side of the housing, the pinion should still be in the centre ? yes, r31 would be easier, but there's none around here. i can get vn diffs for nothing.Originally posted by SR20 KE30 View PostShould have started with r31 skyline diff, more ideal length for what you are doing so pinion would end up more centre, 28 spline, same 4 stud as the front, same diff centre.
this just in, the steel turned up today. i've got the first bit of hollow bar chucked in the lathe and have bored it. just got to knock the outside down now.Originally posted by SkompaThe throttle linkages jammed on the CDs in my old Triumph 2000 and stuck it at WOT.
it's cool man. for a moment i thought i'd fucked up somewhere.Originally posted by SR20 KE30 View PostYep true, just re-read the first post, axle difference of 100mm, cutting 100mm off each side.
From memory i thought the short axle needed extra shortening to be the correct length, but my memory failed.
thanks for that. i'd been thinking about how to do this bit. so you reckon get the diff sitting on the spring mounts, with the u bolts just firm then put the wheels on. then bounce the suspension and do some measurements ? 4 degrees down from vertical for pinion angle ?Originally posted by Momus View PostCheck and measure twice, (preferably by sitting the diff on the springs), for the pinion position in the tunnel and for the angle/tunnel vertical clearance.
Much grief to be avoided.
Its 40mm hollow bar the spacers are turned out of mild steel, i just took the bearing cups to a machine shop had them make them for me, i think they cost about $60Originally posted by caged View PostWhat size bar did you use, and is it just mild steel? did you just spin the spacers down out of alloy? Looks fucken great, might do a borgy for the express van.
I didnt have to straighten my housing as it was within 1mm from end to end, i kept turning the bar as it was being welded to see if the tubes were being pulled around with the heat, if it got slightly tight we move to another spot and pull it the other way
The pinion angle was set while i was building the jig, I just bolted some angle iron to the sigma pinion flange and set it plumb with an angle finder, the angle iron just sat on the jig and propped the diff/pinion up at the right height, then i welded the suspension points to the jig
when it came time to weld the suspension brackets to the new housing i just bolted the angle iron to the pinion flange set it plumb with an angle finder, bolted the brackets to the jig and welded them on
Im not the sharpest tool in the shed and to tell the truth it was easier to do it than it is to explain lolList of cars goes here
so i've been back into the wagon lately. i have turned up the 2 adaptors that go inside where the carrier bearings go. next is the bits for the end of the axle. pics when something happens.Originally posted by SkompaThe throttle linkages jammed on the CDs in my old Triumph 2000 and stuck it at WOT.
