Originally posted by 9triton
View Post
Radiator stop leak
Can tell you from experience that if you're pressurising the cooling system this is a shit idea beacause it makes it easier to push all the coolant out..."Where can we get hold of a Vincent Black Shadow?" "Whats that?" "A fantastic bike," I said. "The new model is something like two thousand cubic inches, developing two hundred brake-horsepower at four thousand revolutions per minute on a magnesium frame with two styrofoam seats and a total curb weight of exactly two hundred pounds."
fuel tank putty/knead-it stuff. Jam a gob of that shit on there. Works really well, doesn't block up the core or coat the cooling system, and it's easy for the repair shop to knock it off and repair it properly when the time comes.
Also, it's cheap as shit and very easy to use.Turns out, far too much has been written about great men and not nearly enough about morons
pepper/egg should burn away when they go to solder it. well its never been mentioned it was a cunt when i got a radiator fixed properly after doing the pepper trick anyways.Originally posted by Rdyno70ynu has to be the most retarded cunt here. "Help me please" me "you need to remove your head" him "fuck off cunt I'm to lazy fuck off out of my thread you told me to do something I don't want to do so you're a cunt fuck off can some one please tell me an easier way???"Originally posted by TripperIts a tight battle between you and rogercordia for the most retarded member on here, thou i think you have it by 5 window licks
pepper is fine. May reduce the leak to a weep rather than actually fix anything though.
egg and stop leak can be problematic, particuarly the stop leak. It coats everything and reduces the thermal efficiency. Not only does it often block up the rest of the rad core it seems to cause the engine to run hot even after the rad is repaired due to having coated the cooling system.
Egg only works on tiny pinholes and is hard to flush out. Makes everything stink too.
Knead-it mate. Short of solder, it's the only thing that really works and won't cause issues later on.Turns out, far too much has been written about great men and not nearly enough about morons
Not sure if I can get to the hole to use knead-it or similar. It looks like its coming from a tube in the core, I think it's a radiator out job no matter what so I will limp it to the next town and set up base for a few days and pull it out. Once it's out I will see how accessible the hole is and go from there.
If I was to just solder it do I just use regular solder and soldering iron? What should be the most perminent fix? Solder or knead-it/metal bond etc?
Sydney Dents
Paintless Dent Removal
knead it will work fine on the core. usually it's the front or back of the tube that gets a hole in it usually from a stone, if so, just push the knead it against the tube that is leaking. if it's split down the side of the tube then poke some fins out the way and poke the knead it in.
you will need normal flux solder and a decent plumbers type propane torch to solder anything. solering iron won't put enough heat in.Turns out, far too much has been written about great men and not nearly enough about morons
You know whats going to happen once you red neck the repair? You are going to be going through drive through in maccas and theres smoke pouring out of the engine way and you can't do anything about it as there is a queue in front of ya!
I took my condenser to a radiator place to get repaired due to a leak in the core and it only cost $30.00. Cheap as.
It won't fit in a drive through so that's fine, plus I don't eat macca's.
I have semi bodged it, put a little bit of the radiator stop leak in it.
Only reason was because there was no pepper available and there was only a servo near by. Once I get to a more populated area I think I will just try to get it recored or try to find a complete new one somewhere. It has lasted about 500klm so far with no further issues. By the looks of it corossion was the cause not a rock or anything hitting it, so it probably needs replacing anyway.
Sydney Dents
