th400 or Powergilde
    Originally posted by 60TJZ View Post
    1t car
    2j - approx 900hp fly
    too light for mod plate.
      Another vote for T400 (or any 3 speed really).
      You could even investigate a 3sp Jatco.
      IMO on the street where you won't be properly stalling it up a 3spd should be a bit snappier and less doughy than a PG due to the shorter ratio 1st gear.
        I'd prefer a 3sp auto if it's driven on the street & you also think you can make it hook up on launch at drag strip...if not then powerglide as second choice.
        Th400 will be much cheaper & heaps stronger than a th350 with only real benefit of being smaller,easier to fit.
          I a c4 fan
          they can be built to cope with 1200+ hp
          List of cars goes here
            I would go a 3 speed aswell if you going to be doing any street driving.
            Mate has a 2speed glide and its rather fail on the street.
              How heavy is your mate's car?
                Don't they say if it is under tyred then you want the glide so less potential to break out in wheel spin at the drags?
                3D scanning
                3D modelling
                Structural certification
                3 and 5 axis milling
                  Its an S15 200sx. 600+rwhp. Only problem is, if you want to roll on from about 70, its too fast for first gear, too slow for top. Other then that, its ok.
                  Pretty much.
                    Yeah I wouldn't be using a glide in a 1250kg 2 litre
