i would have thought you would need to know what revs you will be pulling - ie can the crank take eg 7500rpm . i know the ford kent pushrod fours they end up with a full steel crank for hi revs (not sure what the limit is on the std crank).
if you cant get super revs with the std crank+ rods - then can you get away with a std cam/rocker set up ?
probably no point in going to the trouble of roller cams , rockers etc - and then spending all that time on a dyno to develop a roller profile if its not of that much benefit
as mentioned here its going to boil down to what revs you can do and what the head will support.
maybe TK can do some sums with EAP and pipemax etc to tell you what is possible with the head -and the mods you are allowed
but i would have thought building a simple reliable engine to allow you to develop the car etc would be first up -then chase the power.
i would have a look at what burton power products in the UK have for the ford pushrod kent engine would be a guide as to whats possible.
as for reducing friction - would have thoughttherea re a number of coatings out there that can be applied
but as above - carry on and post plenty pics
