Jz auto options
    Jz auto options
    If you're making good power ie 125mph trap speeds you need a th400
    Thanks for your time
    Wat?
      We decided we needed a dedicated thread to how good a th400 is
        You have been reading the bullet too much.
        You need a glide......... apparently.
          I see... I think... or not lol
            Surely if you're only trapping 125 the a340 is fine. And if you're dead set on losing overdrive, why not c4 over th400?
              Electronic controlled and shifted lenco
                the guy with the sequential turbo setup celica had a lenco with a clutch.
                I'm also keen on this... gotta be able to do drag challenge & a little street duty & a KM flat out.
                  I think that's the changeover point (there or thereabouts). Once you're doing all the conversion bits (mounts/bellhousing/tailshaft/shifter/speedo) you may as well go to the strongest. I regret going c4 in the Barradore
                    C4 is way too expensive to make it >500hp reliable.
                      Jamming a valve body, convertor and fitting a good cooler in a A340E gets you quite a way and they will handle some power.
                      Issue is, when you blow it up getting it properly rebuilt is a fair chunk less than conversion costs and another transmission, if you legitimately drive it a lot then going back to a 3 speed box is insanity when even a 4 speed these days is a bit gay - so factor in a gear vendors OD for the TH400.
                      TLDR; Unless your making really big power towing the cunt to the drag strip, give the stock box a go.
                        Mine was fine with nearly 600whp 1uz and 135mph.
                          I don't think losing overdrive is that much of a problem for a 2.5 or 3.0 litre motor. The prices I've been quoted to build another strong 340 are similar to the price of a built th400 so you'll only be out the cost of the conversion bits
                            so anyone street drive a CO2 shifted trans? am i going to need to top it up every 100km?
                              toploader or your a faggot.
