CEL - Kia grand carnival U0001 - High Speed Controller Area Network (CAN) code
    Hi,
    Just got the check error light today..
    The ODB code is above U0001.
    I have noticed that fuel consumption has been worse (always pretty bad though (10-11l/100km highway and 15+ around town)
    its been a bit hesitant putting around town, kind of rough but not so that you would think there was somethign seriously wrong
    Some googling says anything from the MAF being dirty/malfunctioning or crank angle sensor?
    Air filter has recently been replaced.
    Any ideas on this?
    U0001 is a generic code outlining "some sort of communication fault on the HS-CAN" as in the Engine Control Module can't communicate with some other module or modules, on the HS-CAN network.
    It is not anything particular to do with engine performance, and I don't know about Kia's, but in Ford, Mazda, Jaguar, Land Rover, etc, this code does not put on the Check Engine Light...
    There is probably another code set, one starting with a P, which has put on the light...
    Originally posted by nutttr
      Does it have ignition leads, or coil on plug?
      If leads, replace them if they look even slightly shit. Hyu/Kia are notoriously bad for leads.
        ok, will do a bit more digging to see if anything is showing up then.. cheers.
