Bosch Bundy Tube - how do I not ragequit with this shit?
    Yeah I need one of those for sure.
      Like $12 bucks from total tools, bought one the other day just cause I could use it one day [emoji846]
        They also have them in at your favourite sausage and bread retailer
          Doing fuel line? Put a hose clamp around the fixed handle to hold the tube in place and stop it moving forward when you bend it round the die with the other handle. If its still shit, change the tube manufacturer. Makes a massive difference as some are very stiff, while others you can bend with your hand. Bosch seem to have fucked up PBR stuff since they purchased them. Used to be real easy to bend.
            Is it single wall or double wall tube?
            Double wall shouldn't kink if you're using a handheld bender.
            Single wall is rubbish and needs a 45m bend radius.
              Yeah I bought a larger and better tube bender and it works - ok-. I managed to get the job done but Iíll use aluminium next time.
              Some research shows the Bosch Bundy tube is shit to work with.
              I prefer the "Reliance" brand of tubing... very nice to work with
                Cheers gents. Iíll try a spring on this stuff and Iíll try a different brand as well.
                Any hookups on suppliers?
                  From the Merc 280 build thread.
                  I need to run a fuel line, return and two PS lines from the boot.
                    Swagelock? They would do it in a heap of sizes for instrumentation and I fine it bends easily.
                      25ft of -6 tubing in alloy... fo $70
                      Royalpurple Oils
                        Bought a bending spring. Works well enough but the tube still flattens and is a cow to get the spring back off.
                        Iíll try the reliance stuff.
                          we use these on all the instrument tube at work. its all 316 swagelok stainless tube but the rollers/ correct size dies certainly help keep the tubing round. every tubing diameter requires its own specific bender. if you try to use the wrong die it will come out shit. also, it should be soft-annealed carbon steel (<130HV) or fully annealed stainless (<200HV) for best results.
                          what's your radius? a 3/8" tube should have a minimum bend radius of 15/16" with a wall thickness of 35-65 thousands of an inch)
                          here is the manual: https://www.swagelok.com/downloads/w...N/MS-13-43.PDF see page 24 for troubleshooting.
                          Oo___oO
                            Can vouch for the swagelock bender, we use a fair bit of annealed stainless tube at work (3/8" and 1/2") and the right bending tools makes life very easy.
                            If you insist on using a spring, lube the tube everywhere the spring will be so its a bunch easier to slip off, I did some 5/8" stainless with a spring and it was not fun at all.
                              Twisting the spring as you withdraw it (so it gets tighter/smaller diameter) helps too
                                Yeah if you do like five 90deg bends in the one pipe with the spring still inside...good luck getting it back out
