Gritty oil...
    Gritty oil...
    Just did an oil change on both cars, the X-Trail is spot on, however the Kraut concerns me. The oil that came out was barely 10,000km old yet felt very gritty. I've organised to get a sample analysed, but thought I'd ask if the PF brains trust had any knowledge on the matter whilst I wait?
    Originally posted by Cock Fist
    You're a penis.
    What do you mean gritty?
    If you rub it between your fingers, whats in it?
      Like there was fine sand in the oil.
      You're a penis.
        What is a Kraut?
          BringMyWallet
          You're a penis.
            Whats the filter cartridge look like?
            Does it have an (working) air filter?
              Air filter is fine, the filter cartridge looked normal.
              You're a penis.
                Do the gritty bits have a penchant for magnets?
                Originally posted by E-Z
                  Magnet test was negative, grits aren't ferrous. Magnesium alloy block with Alusil liners, unless crank and/or bearings are committing seppuku.
                  You're a penis.
                    If there are legitimate gritty particles in the oil that came out of the sump then your filter would be full of the shit
                      I just fished the filter out of the bin, it feels gritty too.
                      You're a penis.
                        get a good amount dilute with solvent see what settles out?
                          Bunnings here we come...
                          You're a penis.
                            Just dilute it with a bit of mower fuel & run it through a paper towel.
                            Are you sure you didn't contaminate the oil change container ??
                              Shall do, just need to find where the fuel can is since I replaced the petrol mower with a Victa 82V electric mower.
                              I rubbed the oil between my fingers as it came out.
                              You're a penis.
