If an engineering shop (in the States) was to measure up a set of under drive pulleys for a 350Z and sent me the info, I should be able to get a mate of mine (fitter and turner) to run me up a set of them fairly easily shouldn't I?
By the time they are landed here they are over a grand
Hence why I'm being a tight prick!
Should I bother getting them measured up or is it eay to calculate the sizes you need?
Are underdrive pulleys worth it?
Hence why I'm being a tight prick!Should I bother getting them measured up or is it eay to calculate the sizes you need?
