pulsar gti-r missing
    G'day
    My gti-r is running like absolute sh##. At idle it is missing once every second or so. And when driving it misses a heap and black smoke is coming out the exhaust (which i assume is unburnt fuel).
    Any one have any idea why it's missing and what i can do to fix it?
    Owner of Shirley - Does the 1/4 mile in a swift 400 meters while getting 3.8 liters to the gallon.
    Check sparkpkug's wiring to them, mass on engine.
    Everything that is used to spark.
    RST
    4 maximum performance only
      Spark is getting to every plug still missing....could it be plugs?
        is the timimg allright?
        sparkplugs could be the problem, i had it with my racer, it sparked, but 15° to early, and one time the sparkplug was dead, but sparked
        RST
          I had the same problem check
          leads
          spark plugs
          throw injector cleaner through it
          3D scanning
          3D modelling
          Structural certification
          3 and 5 axis milling
            how safe is injector cleaner....can it do any harm?
            which is the best one to use?
              1200NISMO - If theres fuel running through exhaust it could also be a boost cut problem. Maybe check the actuator hose if your certain of the boost your running.
              I"d also check the plugs for fouling and or the plug gap. Boost has a tendancy to blow out spark when the right gap isn't used ( had problems with this in the past )
              I've used a mobil octanebooster/injector cleaner solution in my R33 a few times, registered a 13hsp@wheels increase according to the apexi multichecker and didn't seem to harm anything.
              Best of Luck
              Gene.
                i'm pretty sure it's not boost cut related as it misses at idle too. will put some new plugs and injector cleaner in tomorrow see if that helps.
                  Tried new plugs - problem fixed
                  Thanks guys.
                    also - any other problems, try the UK guys first
                    www.japmobiles.com/gtir
                    it's all there - mountains of info :D
                    no i don't own a swift
                      changed plugs........now she purrs like a kitten
