its more than worthwhile on a race car, but a total waste of effort on a road or occassional track car.
yeah, all it does is help try and reduce oil mist in the crank case, by deflecting any oil that would ordinarily drop onto the spinning crank.
oil mist and oil flowing onto the rotating crank can sap a bit of power, and also prevent oil from frothing or collecting in the pan properly which can lead to loss of pressure.
Originally posted by Secoh yeah, all it does is help try and reduce oil mist in the crank case, by deflecting any oil that would ordinarily drop onto the spinning crank.
from what i have seen, the crank scraper 'scrapes' the oil off the crank, not stop oil from dropping onto the crank.
*slaps forehead* quite right, I was thinking of something else
but most of what I said is still applicable anyway
The deflectors that fit inside the sides of the block that prevent oil from the upper motor dropping straight onto the crank.
