Okay, this is probably a REALLY stupid question, but I don't know the answer so I must ask...
I'm changing the bellhousing on my T50 (from the T to the A), and when I took the old bellhousing off I noticed it has a bit of a gasket between it and the gearbox... Do I need to get a special gasket to put the new bellhousing on? Is it a generic T50 one? Or do I cut one out of gasket paper? Or just use gasket goo? Anything I should watch out for when changing the bellhousing (apart from gear oil everywhere...)
Thanks
Thanks
Someone else told me not to use a gasket but instead to just use gasket goo... I suppose either way should work...
