The VLT injectors also run a different pulsewidth to the NA ones. You will have to run a VLT ECU on a RB30e motor, im not exactly sure about the RB20DET's, but you should check it out before doing anything, better safe than sorry!
MZ11 Soarer - 1G-GTE Going in...
R31 Skyline - RB30e... Do i hear a truck?
86 Laser - T-Bar... enough said.
