I have just bolted up a kmac 26mm front sway bar - but the front bushes (holding the bar to the front of the car) i have are suited to a 23mm diameter bar.
The bushes are a very hard urethane and have almost no give in them. I have managed to bolt it on, but i am worried that the bushes will be too tight and the sway bar wont be able to move.
Is this likely to happen? Will it cause me to die ?
The split in the bush, that would be closed on the correct size bar is about 2-3mm apart when installed.
Please help!
Please help!
