Pre Ignition and Secondaries questions.
    riiiight. Carby shall be left alone to live another day. Thing is new plugs went in and it made the cold start miss go away but opened up a whole new can of worms when its warm under slight slight throttle. *looks at carby* i will get you, one day. :p .
    Project HOUSE!!!
      Originally posted by Secoh
      exactly! The number of times an owner or apprentice has faffed around with the carb due to a set of points being worn out or an arcing rotor button, or a failed condenser is unbelievable.
      Damn you guys! Damn you to hell!
      I wish I had have read this before I pulled my Carby to bits.
      After putting it back together to find the car no longer starts freaked me out as I thought I'd completely stuffed up. Turns out I just needed to replace the things mentioned above as well as the ballister(?) resistor for the coil and all was sweet.
      Just have to put it down experience. The amateur I am.
        every time I have to do something on the car I learn something new. all normal...
