Dont think I coul fit the 8 in and i dont know of any other 4s that would fit the mouting brakets or bell housing and cost is too much to move (make) new braket and running im running on modorate budget
hehe yeah but you could buy a 928 for under $20k and sell the motor and box, and do a complete conversion and come away with a portch that owes you $10k in total! and go harder :D
Merlin, I believe the cylinder heads are interchangeable between the 4 and the 8, well the right hand one is anyway. Perhaps a lot of other things are very similar as well. If the engine mount locations and bell-housings are interchange, it might not actually be that difficult.
A lot of manufacturers are waking up to the economy of making modular engines that can share a lot of components. So a slant four can also be made as a V8, and a straight six as a V12.
You can get import 928s for less than $10k, apparently - a mate found somewhere that had a couple for about $7k each.
Frankly, I'd much prefer a 928 myself... Only portch that I could pretend to afford that does anything for me.
the source:
The engines suggested above would probably upset the handling and balance a fair bit..... The other issue is that from memory the 924 box is in the rear is it not? therefore youd be moving a lot of weight forward.
(TM - AVENGE)
but just quietly, ive been thinking for the last 6 months or so of doing a worked NA 1uz into a 928...
now ive not gotten too far into researching this, not even seen a real 928 in the flesh to eyeball the bay, but does anyone know if a 1uz would potentially fit??
dont be concerned with engine mounts blah blah blah - that can all be fabricated, im just interested in "will it fit" ??
also on a side note, what does the 928's native engine weigh?
cheers
ed
Mit freundlichen Grüße
The 928 has a similar layout with the box at the back, That is just another reason why fitting a 928 donk would probably be a far easier proposition than fitting anything else.
How much it weighs I would not have a clue, but the later 928 motors have quad cams and four valves per cylinder. The technology is every bit as good as the Japanese engines.
I am thinking why bother?...I recently looked at a 944turbo for 14500 with service history.....better bet than a soggy 924?
928 engines are nice and power upgrades are easy...but its all expensive.....could not think of a good reason to 1uzfe a 928.
re the sc...look on ebay america. there is a new whipple lysholm blower for $1000 usd....a good price
Sir John Monash
