Poor compression on 1 cylinder ... where to now ?
    With any sort of ring problem, you are going to either be blowing smoke, or have lots of blow-by into the crankcase. If you have neither, and nothing else appears to be obviously wrong except a slight loss of power, the valve theory sounds pretty much the best bet.
    Tony
      I agree with Warpspeed there
      Also, some mitsus used a little 3rd valve for EGR purposes which sometimes crap out and burn away. does the 4G93 use these? if so, unscrew them all and check the ends. I have gutted them before and braized up all the holes as these things caused a LOT of problems in things like L300's and express vans.
      Sorry but im not that familiar on "modern" mitsus... I suspect they did away with those poxy EGR valves on the twin cam heads...
        Originally posted by gianttomato
        Sell or trade in. I wouldn't keep it for long.
        Originally posted by Secoh
        if you arent willing to lift the head off for further inspection, then either drive it till it dies or sell the car.
        I can see the thread now "Help Lancer Turbo Running on 3" by its new owner
        PM me for more info
