driving my turbo honda city home the other day and it started to severely miss(sounds like a wrx now) and not boost. Made it home and checked the leads and plugs as it sounded like an ignition miss but they were both fine. THought i may have done the head gasket but the oil and radiator fluid was fine and doesnt overheat. Also ripped off the turbo and no shaft movement or stuffed manifold gaskets and checked all intercooler and vacuum hoses without luck.
My next step will be ripping the fuel pump out and checking the regulator and lines for a blockage. The fuel pump is only 2 months old and is a vl turbo, i can hear it working but there may be something blocking it.
Any ideas if this dont work?
cheers
cheers
